Error 200 when uploading images with iPhone
Robotaz
Rob, this is a strange problem and only appears to happen with photos in an iPhone library. And it's not consistent. Most of the time when you edit an image first like cropping, rotating or enhancing, it uploads fine after that. Can you give that a try? I am still researching the exact cause and a fix.
  • 2 weeks later...
The problem appears to be caused by Apple's HDR photo format. When you have it set to Auto or ON, the -200 error will show. When you have your camera app set to Auto, it may or may not happen because not all pictures use HDR.
So the work around is:
  • edit and save a picture before uploading to the site
  • turn off HDR in your iPhone camera app settings
Hopefully the software developers will fix this bug eventually.
